The table that follows shows Run and Debug DIAL command codes (set by SET RUN @I$DIAMASK session command).
Code |
Module |
Description |
Dial‑A |
AECOLL AEPROM AESTAT |
AEF Statistical collector Print a formatted object module Object module statistical collector |
Dial‑B |
AETINT |
AEF maint‑code executor |
Dial‑C |
AETPGM ADRUNP ADRUPP |
AEF program control AEF driver module Run post processor |
Dial‑D |
AEPLIP AETRUN |
PL/I batch interface AEF T‑code interface: Run control |
Dial‑E |
AEDB2D AEFUNC |
AEF Dynamic DB2 SQL I/O mod AEF String functions |
Dial‑G |
AELPGM |
AEF LOAD/LOCATE PGM |
Dial‑I |
ADMODP ADPLAG AEINIT AERCBP AESTAT ADRESR |
CRE/DEL/IDE MODULE commands GENERATE PLAN processor AEF Run‑time initializer AEF dynamic RCB processor Object module statistical collector DB2 APRES retriever |
Dail‑J |
AETSQL AEDB2P ADDBQI ADSQLE |
SQL logic module AEF DB2 SQL T‑code DB Q‑COMMAND INTERFACE PGM BATCH DBSQLE |
Dial‑K |
SDBUGP SDTREN |
Symbolic debug dispatcher SYMBOLIC DEBUG TRANSACTION END |
Dial‑L |
SDIDEN SDOUTP SDBUGP SDEDKP SDGDAT SDXTAB |
Debug: look up identifier SYMBOLIC DEBUG OUTPUT PROCESSOR Symbolic debug dispatcher DEBUGGER EDK SERVICE PROC Debugger generator data display member DEBUGGER EXTERNAL BREAKPT MGR |
Dial‑M |
AETMAP |
AEF panel T‑code processor |
Dial‑P |
AEAUXP AEPSS |
AEF ASSIGN commands AEF PSS driver |
Dial‑R |
AERWDR RWEXEC RWEX20 |
AEF Report Writer driver RW: Execution control RW: Execution control |
Dial‑S |
AELSYM |
AEF load and locate symbol table |
Dial‑T |
AELMAP |
AEF LOAD/LOCATE PANEL |
Dial‑V |
AETDVV AETDVW |
Extension of AETDVW AEF T‑code for dataview I/O |
Dial‑W |
AETDVW |
Dial‑X |
AERLSE |
AEF cleanup processor |
Dial‑Z |
AETERR SDRTAB |
AEF error handler DEBUGGER RUN‑TIME STOP TBL BLD |
