Previous Topic: InputNext Topic: Error Recovery Tools
Output
The following illustration is the resulting output:
IDEAL DISPLAY OUTPUT OUT INDEX DISPLAY P.S.S. - ONLINE UTILITY STATUS OF THE LIBRARY ADROUT DATE 09/30/04 TIME 11.59.56 MEMBER NAME MEMBER DESCRIPTION NREC NBLK ADDED UPDATED RLEN ===================================================================================== PSS$PSSDIR$ *** PSS SPOOL DIRECTORY *** 0250 0014 070690 073199 0179 PSS$PSSDST@ PSS - DESTINATION TABLE 0012 0002 071190 071903 0024 PSSSCF#0052 COMPILE LISTING 0021 0002 071904 071904 0133 PSSSCF#0053 COMPILE LISTING 0133 0004 071904 071904 0133 PSSSCF#0054 COMPILE LISTING 0109 0004 071904 071904 0133 PSSSCF#0056 COMPILE LISTING 0350 0006 071904 071904 0133 PSSSCF#0057 DISPLAY INTERR: 0009 0002 071904 071904 0133 PSSSCF#0071 COMPILE LISTING 0118 0004 071904 071904 0133
The output directory in this example is the member PSS$PSSDIR$, which contains a system name of PSS and a directory name of $PSSDIR$. You can set both system name and directory name with the command SET OUTPUT OPTIONS.
