Previous Topic: OutputNext Topic: Input
@I$UTIL PSS Online Debugging
PSS provides several online commands for maintaining the output library (ADROUT). They let you obtain information on the current status of the output library and obtain an index of all members in the output library.
The following command displays or prints the current status of the output library.
@I$UTIL OUT STATUS [print-name {SYSTEM } name]
                   [           {NETWORK}     ]
print‑name
Contains the name identifying this display or print.
name
Contains the destination ID of the system printer or network printer.
The command provides the following information:
Example
The command @I$UTIL OUT STATUS alone displays status information online at your terminal.
The following submits the output to print on network printer HR86 with the identifier MYLIB:
