DIAL trace entries can be interspersed with VPE trace entries in the trace listing or they can be separated. DIAL entries are free format. VPE trace entries display the following columns of information:
Time...usr r trace-entry......cmp function...rc..aux-data...
Time the entry was logged
Three‑character short user ID
Region number (1, 2, or 3) or *0 for asynchronous task
VPE trace entry in hex format
Component name
Function name
Component return code
Auxiliary information
For each entry, the hex trace data, time, user, and region come from the VPE trace file. @I$TRACE PRINT extracts the component, function, return code, and auxiliary data in symbolic form from the hex trace entry.
The beginning of each data block in the trace file is marked on the trace listing with a row of asterisks, with the block number, date, and time of the entry shown as follows:
ADPLOG Ver: 11.0 IDEAL 11.0 print trace facility. Date: 04/12/06 Time: 12:07:54 User: WESJO01 Selection criteria: Date mmdd Time hhmm/hhmm User xxx Func ALL/ xxx/ xxx/ xxx/ xxx/ xxx Blocks nnnnn/nnnnn time.... usr r trace-entry 1st 16 bytes........ cmp function rc.... aux-data..................... ******************************************************************* block=0000001 Date=04/11/06 Time=15:49:06 15:49:06 WJW 1 06000000000A984E0000000000000000 VPE $EXT-n 00 pgmn=@IADTRCE 15:49:06 WJW 1 06000000000A984E0000000000000000 VPE $EXT-n 00 pgmn=@IADCMD2 15:49:06 WJW 1 06000000000A984E0000000000000000 VPE $EXT-n 00 pgmn=@IADCMDP 15:49:06 WJW 1 020000000018E1100000000000109C50 VPE $CSP-n 00 pgmn=@IADCMDP parm=00109C50 15:49:06 WJW 1 AA0000000005C3000000001700109B19 IDL CMD-C 00 CAT DVW SYSADM.DIR_AREA 15:49:06 WJW 1 020000000019056C000000000010A4E8 VPE $CSP-n 00 pgmn=SC00EACP parm=0010A4E8 15:49:06 WJW 1 06000000000A984E0000000000000000 VPE $EXT-n 00 pgmn=SC00EACP 15:49:06 WJW 1 0200000000190714000000000010A4E8 VPE $CSP-n 00 pgmn=@IADENDP parm=0010A4E8 15:49:06 WJW 1 AA000000000200000000000E0016B258 IDL entered 00 pgmn=ADSVCS 15:49:06 WJW 1 501068900001E201D30000340010930C SCF CVT-loc 00 CB name=ADMAINCB 15:49:06 WJW 1 AA1ADB6A00000000D3D6C3C30010E4E4 SVC LOCC 00 ADMAINCB 15:49:06 WJW 1 AA000000000200000000000D0016B5C8 IDL exited 00 pgmn=ADSVCS 15:49:06 WJW 1 02000000001AD8A2000000000010E5C0 VPE $CSP-a 00 pgma=00000000 parm=0010E5C0
