The environment page is always first. It shows the following information:
An environment page sample trace is shown as follows:
ADPLOG Ver: 11.0 IDEAL 11.0 print trace facility. Date: 04/12/06 Time: 11: Selection criteria: Date mmdd Time hhmm/hhmm User xxx Func ALL/ xxx/ xx Command entered : @I$TRACE PRINT The primary function of this module is to print IDEAL trace. This program provides a group of commands designed to select information from the trace file. The commands are as follows: - DATE mmdd to select a specific day in the month - TIME hhmm to select from a given time - TIME hhmm/hhmm to select a range of time - BLOCK nnnnn to select from a specific block - BLOCK nnnnn/nnnnn to select a range of blocks - USER uuu to select a specific user-id - FUNC fff/fff/... to select up to six functions - FUNC ^fff/^fff/.. to exclude up to six functions - FILE iiiiiiii to change the name of the input file - NAME oooooooo to change the name of the print file - STATISTICS to print only the statistics The values for "fff" are the following: - VPE, VLS, PMS, PSS, SCF, DIL, LOG, - CMD, SVC, DSF, ENQ, PGM, EDK, BAS, SQI The following software was used: Monitor=CICS Opsys=MVS/JES2 VPE(11.0) SCF(1100) PSS(1100) PMS(110 ) EDK(110 ) PDF(110 ) DSF(11.0) IDL(110 ) ADPLOG Ver: 11.0 IDEAL 11.0 print trace facility. Date: 04/12/06 Time: 11:
