Previous Topic: DISPLAY PCT CommandNext Topic: Application Debugging Tools
Display LMT Command
This command can display different results from the DISPLAY INDEX ALL MODULE command, which reflects only the Datadictionary MODULE entities.
The DISPLAY LMT command displays the content of the Load Module Table, which may be a composite of entries loaded from Application Module Tables, and entries retrieved from the dictionary. For more information about load module format, see the Administration Guide.
The following is an example of the report this command displays:
PGM $ID CICSWEB (PRD) IS MODULE CICSWEB PGM CTH A8842296 (PRD) IS MODULE ADAM1 PGM CTH B8842296 (PRD) IS MODULE ADAM2 PGM CTH A7698144 (PRD) IS MODULE A769814 PGM CTH B7698144 (PRD) IS MODULE B769814 PGM CTH C1198608 (PRD) IS MODULE CM98608 PGM QAT CUST (PRD) IS MODULE CUST PGM CTH C9370687 (PRD) IS MODULE C937068 PGM CHE DATE (PRD) IS MODULE D1 PGM SOL ID#2192 (PRD) IS MODULE ID#2192 PGM SOL ID#2773 (PRD) IS MODULE ID#2773 PGM SOL ID#2818 (PRD) IS MODULE ID#2818 PGM SOL ID#2854 (PRD) IS MODULE ID#2854
