Previous Topic: DUPLICATENext Topic: DELETE
MARK STATUS
PGM
The only VLS members affected by the MARK STATUS command are program object members. For the program executable object (type T) and symbol table (type J), the members are renamed so that the version number is changed to PRD. In addition, if there is a previous PRD version of the same program, the associated members are renamed so that the PRD is changed back to the original numeric version number.
Note: This description of the MARK STATUS process is only valid within the CA Ideal environment. The VLS members are not affected by STATUS changes made only in the Datadictionary environment to the dictionary ENTITY.
This lets the run‑time executor locate the appropriate members in a system that was the target of the Transport Utility, when no Datadictionary entity‑occurrence exists. This is necessary to support the command RUN xxxxxxxx VER PROD, since otherwise CA Ideal has no means of determining which of the multiple possible versions of the object members were the production versions.
Example
Suppose that in SYS ACC, PGM UPDATE VER 005 is currently in PROD status. VER 006 and 007 are in TEST and VER 006 is to become the new PROD version. Before the MARK STATUS command, the following members exist in the object library. If you run a VLSUTIL LIBRARY listing, the member names are shown in strict collating sequence order instead of the order shown:
ACCUPDATE            PRDJA
ACCUPDATE            PRDTA
ACCUPDATE            PRDTB
ACCUPDATE            005VA
ACCUPDATE            006JA
ACCUPDATE            006TA
ACCUPDATE            006TB
ACCUPDATE            006VA
ACCUPDATE            007JA
ACCUPDATE            007TA
ACCUPDATE            007TB
ACCUPDATE            007VA
This program contains working data but no parameter data. We can determine this because there is a type V member (working data object) but no type Q member (parameter object). Also, the original MARK command for VER 005 changed only the names of the type J (symbol table) and T (executable object) members to reflect PRD instead of 005: The type V member was never changed. A type Q member would not change either.
In this example, only two members are shown for each executable object module: A and B. There can be more members (C, D, E, and so forth), but two is the minimum.
The following is now executed:
MARK STATUS PGM UPDATE VER 6 TO PROD
CA Ideal determines that there is an existing previous PROD version of the program by accessing the Datadictionary. After the above command is executed, the following members exist on the object library (if you run a VLSUTIL LIBRARY listing, the member names are shown in strict collating sequence order, instead of the order shown here):
ACCUPDATE       PRDJA
ACCUPDATE       PRDTA
ACCUPDATE       PRDTB
ACCUPDATE       006VA
ACCUPDATE       007JA
ACCUPDATE       007TA
ACCUPDATE       007TB
ACCUPDATE       007VA
All members for the old PROD version 005 were deleted (since CA Ideal could determine from the Datadictionary that version 5 was the previous PROD version). The former 006 members were renamed to PRD since the command directed CA Ideal to mark version 6 to PROD status. Also, neither of the type V members (working data object) was affected by the MARK STATUS command. These members are used only at compilation time.
For all other entities, MARK STATUS only affects the Datadictionary definition. The corresponding VLS members are not updated.
