Previous Topic: CREATENext Topic: DUPLICATE
EDIT
DVW
For an unmodeled dataview, a copy of the member on IDDVW is made with an edit‑indicator of E. At normal end of EDIT, the E member is deleted.
MEM
Makes a copy of the data member on the IDDAT library with an edit‑indicator of E. At normal end of EDIT, the E member is deleted.
PGM
A single program can result in up to three separate source members on the source library: Procedure (type L), working data (type W), and parameter data (type P). Each member is first created when the corresponding component is first edited. In addition, any time an EDIT is issued for a given component (including when it is first created), a copy of the member is made on the SOURCE library with an edit‑indicator of E. When the RESOURCE definition is edited, a temporary member (type E) is created in IDDAT, as well as a copy of the member with an edit-indicator of E. At normal end of EDIT, the E members are deleted.
PNL
Defines a copy of the panel member on the panel library with an edit‑indicator of E. At normal end of EDIT, the E member is deleted.
RPT
Defines a copy of the report member on the source library with an edit‑indicator of E. At normal end of EDIT, the E member is deleted.
Note: If E members are left on the source or IDDAT libraries due to edit sessions being abnormally terminated, VLSUTIL DELETE may be used to remove old E members.
