The following table shows how CA Ideal application components (systems, users, dataviews, data members, panels, reports, programs, and plans) are recorded in the Datadictionary, stored on a VLS library, or both. For descriptions of VLS member name formats and details of how CA Ideal commands affect VLS members, see Appendix B, “VLS Members and Utilities.”
VLS Libraries |
Component |
Dictionary |
Source |
Object |
Panel |
*IDDVW |
IDDAT |
SYSTEM |
x |
USER |
X |
DATAVIEW |
X |
X |
MEMBER |
X |
PANEL IDENT |
X |
LAY/SUM/EXD, etc. |
X |
X |
REPORT IDENT |
X |
PAR/HEA/DET/COL |
X |
PROGRAM IDENT |
X |
RESOURCE |
X |
PARAMETER |
X |
X |
X |
WORKING DATA |
X |
X |
PROCEDURE |
X |
X |
X |
*PLAN |
X |
X |
* A DB2 site can define a separate plan library.
