You can receive similar error messages when marking panels and reports to Production status as when marking programs. Follow the same steps as you would for programs.
Enqueues are also done on user definitions. If you try to mark a user definition to Production status while the user is already signed on, you receive the message:
IDADUEDS02-User Definition In Use, Please Try Later
Check if that user is active online or in batch. If so, have the user sign off. Do not issue the DEQUEUE command.
The same is true with system definitions. If a user selected a system, you receive the message:
IDADDSEDP02-System Definition In Use, Please Try Later
Check if anyone is in that system, running a program from the system or editing and displaying entities in that system. If so, have them select another system definition. Do not issue the DEQUEUE command.
