Previous Topic: Dependency SpecificationNext Topic: ASCII File Modification
Use of Pre- and Post-Programs
To use the functionality of pre- and post-programs, you must create the actions.sxp file manually, using the Create archive file method. You can add the pre- and post-programs to the product by means of the Import archive file method.
If you use parameters in the pre- and post-programs, you must list the files containing parameters in the #ReplaceParams# or #ReplaceParamsUNICODE# sections.
