The pc.ini file contains the deviations for each PC from its PC group, or from the default object if the PC is not assigned to a PC group.
If there is no section for a PC in this file, the defaults for its PC group file (in the group.ini file) apply automatically. If the PC is not assigned to a PC group, the defaults from the default.ini file apply automatically.
Each PC that has at least one parameter different from the default receives its own section in this file. Each section has the same name as the PC to which its parameters apply.
[pc0_1] parameter2=48 parameter3=08/15
[pc1_1] parameter3=1xyz
[pc2_1] parameter1=8
[pc2_2] parameter4=purchase
