The group.ini file contains several sections. Each section must be named the same as the PC group to which its parameters apply. Each section contains only the parameters that differ from the default parameter values in the default.ini file.
The entries in the group.ini file consist of the name and value of the parameter only, since the type and range of a parameter cannot be changed.
A sample group.ini file follows:
[group1] parameter4=clearing
[group2] parameter3=payroll99
[group3] parameter1=9
