Previous Topic: Common Files and DirectoriesNext Topic: Specify Install and Delete Options for Files
User Files and Directories
You can configure the user-specific files in the same way as the common product files, using the version-dependency button and the reference counter-dependency button. In addition, two options are available for user-specific product files, as follows:
Icon for the file option Install file only if not existent
Install file only when file does not exist
This option protects user-specific files against overwriting by newly installed software. For example, if a user has already created a dictionary for office applications and a more recent office application is to be installed, this option ensures that the user's dictionary file is not overwritten by the application's default dictionary.
Icon for the file option No file removal during uninstall
Do not remove file during uninstall
This option helps the user to keep a user-specific file (for example, a dictionary) on the target computer even if the application to which it belongs is uninstalled. The dictionary file may also be useful for other applications that remain on the target computer.
The following screenshot shows a sample User Files and Directories tab:
Sample screenshot of the User Files tab on the List of File System Changes dialog
The settings on the User files and directories tab of the List of File System Changes dialog are applied to the product in the ufiles.sxp and udirs.sxp archive files.
