Previous Topic: Wake-on-LAN SupportNext Topic: Deciding on a Security Mode
Set Up Host Protocols
In a stand-alone environment, you need to set up a network protocol for the host.
To set up the host protocol
  1. Select the TCP tab in the DSM Properties - Remote Control dialog.
  2. Click the Enabled check box.
    Fields on the TCP tab become active.
    Note: Only users with administrator permissions can change the network settings.
  3. Click OK.
    Your settings are saved and the DSM Properties - Remote Control dialog closes.
