Previous Topic: How to Deploy Stand-alone Hosts with Preconfigured UsersNext Topic: Modify the defaultusers Parameter in the XML File
Extract XML Files
You can perform an MSI Administrative install to extract the XML configuration files from the installation media.
To extract the XML files
  1. Open a command line window.
  2. Change the directory to the WindowsProductFiles_x86\AgentRC folder on the installation DVD.
  3. Execute the following command:
    MSIExec /a AgtRC.msi
    An installation wizard appears.
  4. Enter a suitable location for the extracted files.
  5. Click Finish.
    The XML files you need to edit are extracted to [Path]\Program Files\CA\DSM\bin for Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008 configuration files.
More information:
Control the Visibility of Viewer and Host Properties
Customizing Remote Control
