There are multiple methods for accessing the Replay Export tool.
To access the Replay Export tool, choose one of these methods
Quick Export automatically starts the conversion process using default encoding options and requires no further input.
Export to Video invokes the Export Options dialog, enabling you to view or modify the default encoding options before starting the conversion process.
Note: For detailed descriptions of the Quick Export feature and the Export Options dialog, see the Remote Control Replayer section of the DSM Explorer Help.
For example, the following command converts all of the recording files in the current folder to Windows Media Video format, using the best available codec and default encoding options:
rcReplayExport /WMV *.urc
