CDs or DVDs
CreateOSImage -I <name> -o <REDHATES50(x64)-CD or REDHATES50(x64)-DVD> -a <NFS share name>
CreateOSImage -I <name> -o <SUSE102(x64)-CD or SUSE102(x64)-DVD -a <NFS share name>
Specifies the name for the external NFS share.
The command reads the setup files from CD1 or DVD1 and stores the files on the Image Prepare System / Boot Server.
Directory Structure
CreateOSImage -I <name> -o <REDHATES50-CD or REDHATES50-DVD> -s < distribution files path> -a <NFS share name>
Specifies the path to the directory that includes at least the directory images\pxeboot\.discinfo and the rpm package Server\syslinux*.rpm from CD1 or DVD1.
CreateOSImage -I <name> -o <SUSE102(x64)-CD or SUSE102(x64)-DVD> -s < distribution files path> -a <NFS share name>
Specifies the path to the directory that includes at least the setup files boot\* and the rpm package suse\i586\syslinux*.rpm (for 32-bit) or suse\x86_64\syslinux*.rpm (for 64-bit) from CD1 or DVD1. For more information about the folder structure, see Merging the Files from SUSE CDs or DVDs.
Note: If you do not provide the syslinux*.rpm package, you must add syslinux.com later. For more information, see the section Adding Syslinux.com to the OSIM image.
Before creating the SUSE OS images, merge the files into a specific structure. The structure varies depending on the version of SUSE and the architecture.
Note: After merging the files, copy the parent SUSE folder to the NFS share.
SUSE 10 32-bit OS Images
suse
SUSE 11 32-bit OS images
suse
SUSE 11 64-bit OS Images
suse
The NFS share must contain the merged CDs or DVDs of the Linux distribution for SUSE versions 10 and 11, which is delivered on several CDs or DVDs.
