The default partition schema included in the WinPE boot images may not fit to the schema of the ImageX-.wim file. Therefore an alternative partition description can be used.
A new partition control file <imagename>.wp1 will be created with new ImageX images. The file is located in the camenu directory\share and contains Microsoft diskpart instructions.
New WinPE boot images look for a <imagename>.wp1 file first. If this file is available in camenu, the partition schema will be used instead of the default schema included in the WinPE image.
You can modify the <imagename>.wp1 according to the Microsoft diskpart documentation.
