To create OSIM install jobs to prepare images:
Parameter |
Description |
OSImage |
Specify "getimage" or "getwepos" depending on the support OS type. |
BootSpecial |
Specify "WinPE2.2" or "WinPE3.2" |
SysprepVersion |
Specify the name of the directory that contains sysprep files |
CreateImage |
Specify "prepare" |
The model computer boots into WinPE20 and the job execution script <image>.cmd copies the sysprep files from \\<OSIM-image store>\<imagename>\<imagename>\sysprep\$SysprepVersion$ to the hard disk of the model computer. It also copies the OSIM prepare script “osimsysprep.cmd” and the driver registry file and adds execution of the script to the registry (runonce) of the Model computer OS.
Finally the script reboots the target into the OS of the Model computer.
Note: No DSM agent should be installed on the Model PC. An installed DSM agent can’t be removed from the getimage (prepare) function.
Runonce launches osimsysprep.cmd. Osimsysprep.cmd removes OSIM files from previous OS installations, adds the OSIM driver path to the registry and executes sysprep.
Sysprep shuts down the model computer.
On the DSM Manager the prepare job becomes stopped.
