For WinPE images, OSIM provides certain tools that you can use to communicate with the boot server and to manage the OSIM parameters. The tools are available in the Image Prepare System templates and are inserted automatically with the CreateBTImages command so that you can modify an OSIM WinPE image with custom actions. This chapter describes these tools.
This section contains the following topics:
sdmpcimg Command (32bit and 64bit Version)
preplace Command--Substitute OSIM Parameters in Text Mode Files
canet Command-Get Access to OSIM Shares on the Boot Server
decodDat.exe Command--Create a Parameter File With Localized Parameter Values
