For OSIM, boot sequence is an important factor. If you deploy an OS into a system which contains multiple disks (either local or remote, or both local and remote), then, the disk being used for the OS deployment must be the first disk in the boot sequence among all the available bootable disks (disks holding any bootable OS or bootable media).
