Symptom:
When I install a SuSE 9.0 image, the X.11 keyboard settings are not correct.
Solution:
A SuSE 9.0 target installation does not transfer the system keyboard settings to the X11 keyboard settings correctly. The keyboard configuration for the system is set correctly according to the $KeyBoard$ boot parameter.
Workaround: To set the X11 keyboard settings to US, add the following lines to the custom.cmd of your OSIM SuSE image.
Insert after the lines:
# Install the SD Agent (
the following commands:
ed /etc/X11/XF86Config <<EOF 1,$ s/”de”/”us” w q EOF
