Symptom:
Accessing the boot server's DOS share from the OSIM client fails with an "Access Denied" error message or results in "Error 93".
Solution:
You need to configure the security settings of the boot server share.
Perform the following steps depending on the boot server operating system:
Windows 2003 or Windows 2008 boot servers:
The security settings pertaining to the local security policy appear.
Note: You must restart the boot server after changing this configuration.
Windows XP boot servers:
The boot server on Windows XP must have extended file-sharing support. Therefore, you must deactivate the "Use simple file sharing" option. From the Windows Explorer, click Tools, Folder Options, click the View tab, and then clear the "Use simple file sharing" check box.
Note: Boot Server on Windows XP SP3 cannot provide shares for DOS access.
