You must use one of the following procedures to install OSIM:
To install OSIM using the Express Installation Setup on a Windows server
Note: This entails the installation of the OSIM plugin at the domain manager.
The "Select Installation Method" window opens.
The domain manager, the Image Prepare System, and a boot server are installed.
Note: The Image Prepare System is running on Windows only.
To install OSIM using Custom Installation
The "Select Components and Features" window opens.
Note: Do not select any of the other packaging tools.
The installation of a scalability server entails the installation of a boot server.
In the boot server configuration window, click "Enable support for Windows network shares".
The boot server will create read-only network shares using the SMB protocol.
If not, TFTP access is used (default method).
Note: Ghost and ImageX images need share access.
This is all you need to install the OSIM plugin at the domain manager, the Image Prepare System, and a boot server.
