By default, the sdmpcimg command requests1456 data bytes per TFTP packet (blocksize) when initiating a TFTP connection. You can configure the requested TFTP blocksize to improve the transmission time of large files. The requested blocksize is defined in an initialization file sdmpcimg.ini which resides in the same folder as the sdmpcimg binary
Note: Applicable only to Windows PE 2 or Windows PE 3 boot images.
To configure TFTP blockize
Increasing the number significantly reduces the transmission time of large files.
The updated initialization file is included in the boot image. By default, the boot server accepts the TFTP blocksize that sdmpcimg requests. However, you can configure the boot server to limit the effective TFTP block size. To do this, follow these steps :
The policy limits the number of TFTP data bytes per packet for connections initialized by sdmpcimg
Note: PXE firmware, DOS boot images and CA ITCM r11.x or r12 Windows PE boot images are not affected by the parameter TFTP specific blocksize limit. The parameter TFTP blocksize limit can be used to limit the blocksize used with these TFTP clients, see PXE-32: TFTP Open Time-out. DOS boot images and CA ITCM r11.x or r12 Windows PE boot images do not support a TFTP blocksize < 1024.
