Class Permissions are the access rights you specify for the DSM classes which are valid for all the objects of the class. For each security profile, you must specify the class permissions. By default, when you create a security profile, No Access is set for all the object classes. Security profiles with appropriate class permissions give you access rights to CA ITCM. You can specify these access rights in the Class Permissions dialog.
Class permissions are applicable globally to all the objects in a class. If you want to restrict the users to a specific object or folder in the DSM Explorer or grant extended access rights, use the Object Permissions dialog or the Security Group Permissions dialog, respectively.
For example, the class permissions on the Computer object class are applicable to all the computers under the All Computers folder. However, if you want to restrict or give extended rights to a user on a particular computer, then you can specify that in the Object Permissions dialog.
