The Security Areas object class encapsulates the permissions for the security areas. Access rights to this object class are necessary to view, link, and unlink the security areas with the security profiles and objects.
To grant access rights to the security areas
The Security Profiles dialog appears.
The Class Permissions dialog appears displaying the current access rights.
The existing access rights are displayed in the Class access drop-down list.
The given access rights are saved to the selected security profile. Each permission on the security area has the following effect:
Lists the security areas in the domain. When granting the View (V) permissions for the security area, you must also do the following:
Lets you add a new security area.
Lets you delete a security area.
Lets you change the properties of a security area.
Lets you change the Global Settings, like turning on or off the security area support for the domain manager.
