Use the Select User dialog to select a user for whom you want to view effective remote control permissions.
This dialog contains the following fields:
Displays the available security authorities. Select an authority from the directories tree and browse for principals.
The following fields specify the security principal properties:
Displays the container identifier of the item selected in the directories tree.
Lets you use the Add button to select security principals and add them to the Names list.
Identifies the user or group account selected as a security principal.
Lists all security principals whose permissions are about to be added to the address book group.
This dialog contains the following buttons:
Adds selected users to the list of security principals.
Removes a selected security principal from the list.
Invokes the Effective Remote Control Permissions dialog.
