Previous Topic: DSM NodeNext Topic: Administration Console Policy Group
Configuration Parameter Nodes
The Configuration Policy node in the DSM Explorer tree contains configuration parameter subnodes. Because the Configuration Policy node is dynamic, the Default Computer Policy, DSM node displays both common and plug-in specific nodes depending on what DSM-based applications or component plug-ins are installed.
The following configuration parameter subnodes, or folders, contain configuration policies:
Each corresponding pane contains the following fields:
Information
Displays pane-specific tips for selecting options or entering information.
Name
Displays the name for each policy.
Value
Displays the value of each policy. A value may be a string, integer, or Boolean entry depending on the type of policy.
Description
Displays the folder or property description for each policy group.
Note: When a computer policy is centrally managed, the value entered is propagated to all computers referencing the policy.
