Software Contents Download Policy Group
The Software Contents Download policy group lets you view or edit the following policies for software signatures. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: Available categories and options may vary depending on the products and components installed.
Specifies the port number used to communicate with the CA contents server that holds software signatures. Valid values are 443 (new installations) and 5250 (upgrades).
Default: <locally managed>
Specifies the name of the CA contents server that holds the software signatures.
Default: contentupdate.ca.com
Specifies the name of your proxy server.
Default: empty
Specifies the port used by the proxy server.
Default: 0
Identifies the name or ID of the user who has proxy server permissions.
Default: empty
Specifies the password of the proxy server user.
Default: <encrypted>
