Deploy Virtual Applications Policy Group
The Deploy Virtual Applications policy group contains the following policies for deploying virtual applications to target computers. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Indicates the port number used by the Microsoft Application Virtualization server. This parameter applies to Microsoft App-V applications only.
Default: 554
Note: The administrator needs to ensure that the Microsoft App-V Streaming Server has been configured to support the selected port number.
Specifies whether the transport protocol for the target computer is secure or not secure. This parameter applies to Microsoft App-V applications only.
Valid values are as follows:
Indicates that the transport protocol is not secure. The RTSP protocol uses port number 554 as a default.
Indicates secure transport protocol. The RTSPS protocol uses port number 322 as a default.
Default: RTSP
Note: The administrator needs to ensure that the Microsoft App-V Streaming Server has been configured to support the selected protocol.
Specifies whether a roaming target computer uses a new scalability server as a streaming server. If YES, the target computer uses the new scalability server as the streaming server. If NO, the target computer uses the former scalability server as the streaming server at all times.
Default: YES
