Previous Topic: Security Policy GroupNext Topic: Providers Policy Group
FIPS 140 Settings Policy Group
The FIPS 140 Settings policy group contains the following policies for switching the Federal Information Processing Standard (FIPS). You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
FIPS 140 Setting
Specifies the FIPS mode for CA ITCM cryptography. You can select one of the following options:
No compliance level set
Specifies that all CA ITCM cryptography continues to use legacy encryption that is not compliant with FIPS 140 standards.
FIPS 140 approved security functions are preferred
Sets the FIPS mode to FIPS-preferred. In FIPS-preferred mode, the CA ITCM components support both FIPS-compliant cryptography and legacy cryptography to help ensure backward compatibility.
Only FIPS 140 approved security functions are allowed
Sets the FIPS mode to FIPS-only. In FIPS-only mode, CA ITCM components support only FIPS-compliant cryptography and do not support communication with pre-Release 12.8 components.
Change action
Specifies the action to take when you change the FIPS modes in the FIPS 140 Settings policy. You can select one of the following options:
Forcibly restart CAF and all ITCM components
Specifies that CAF and all CA ITCM components be automatically restarted immediately after the policy changes are applied on the target computers and then switch the FIPS mode.
Switch FIPS mode on next restart of ITCM
Specifies that the FIPS mode be switched next time when CA ITCM is restarted.
Politely ask user to restart ITCM when ready
Specifies that the user be presented with a dialog seeking confirmation for restarting CA ITCM and then switch the FIPS mode only if the user confirms.
Note: For more information about FIPS modes and the process of switching FIPS modes, see the CA IT Client Manager Implementation Guide.
