Previous Topic: User-specific SM Installer Policy GroupNext Topic: Non Resident Inventory Policy Group
Web Services Policy Group
The Web Services policy group lets you view or edit the following policies for web services. It contains the following policy group folder:
The Web Services policy group also contains the following policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Garbage collection time out
Specifies the time in seconds to wait before initiating garbage collection.
Limits: 200–300
Default: 300
Maximum number of clients
Specifies the maximum number of concurrent clients that Web Services can support.
Limits: 1–100
Default: 100
Session timeout
Specifies the time in seconds to wait before timing out a Web Services session.
Limits: 600–1200
Default: 1200
Unified login enabled
Indicates whether unified login is enabled for a Web Services session. Valid values are 0=False and 1=True.
Default: 0 (False)
