Previous Topic: Host Events Policy GroupNext Topic: Security Events Policy Group
Manager Events Policy Group
The following event policies appear in the Manager Events policy group and pane. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: For each management event listed below, a value of True means that when the described event occurs the corresponding event is raised; a value of False means the event is not raised.
Address book created
An asset group has been marked as root group in the address book.
Default: False
Address book flag removed
An asset group is no longer marked as an address book.
Default: False
Address book: Add user
A new user has been added to an address book.
Default: False
Address book: Change permissions
The permissions of an address book have been changed.
Default: False
Address book: Remove user
A user has been removed from an address book.
Default: False
Command failed on some hosts
A command failed on some of the hosts of a server.
Default: True
Command not received on host
A server has failed to send a command to a host.
Default: True
Command not sent
A server has failed to send a command to the target host(s) because of a database failure.
Default: True
Command rejected by host
A host rejected a command because it did not originate from its management server.
Default: True
Command sent to all hosts
A server sent a command to all its hosts successfully.
Default: False
Command sent to computer group
A server sent a command to a computer group.
Default: False
Command sent to host
A server sent a command to a host.
Default: False
Computer: Cannot add computer
A server has failed to add a computer.
Default: True
Computer: New computer added
A new computer has been added to a server.
Default: False
Management server failed to start
A management component has failed to initialize.
Default: True
Management server started
A management server has started successfully.
Default: True
Management server stopped
A management server has stopped successfully.
Default: True
Back to Top
