Trace Settings Policy Group
The Trace settings policy group contains the following policies for the path of the trace file. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the maximum number of trace backup files kept on the target system.
Default: 10, <locally managed>
Specifies the maximum number of trace files kept on the target system. This information can be retrieved using the Agents activate procedure, “SM Installer: Get latest trace” or “SM Installer: Get all traces”
Default: 5, <locally managed>
Specifies the name of the trace file. The setup program defines the path.
Default: empty, <locally managed>
