File Transfer Policy Group (Software Delivery)
The File Transfer policy group lets you set the following policies for software delivery bulk transfers. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Indicates whether the use of alternative Data Transport Service (DTS) routes is enabled. Valid values are as follows:
Try all alternative routes.
No alternative routes.
n alternative routes will be tried.
Default: 0
Defines the client ID.
Default: CASD11
Indicates whether compression is enabled. If False, compression is disabled when sending files to an agent.
Default: True
Indicates whether compression is enabled. If False, compression is disabled when sending files to a scalability server library.
Default: True
Specifies the amount of raw data a DTS initiator agent reads before it applies any parcel filters and before it sends the data across the network to the responder agent. The unit value is in bytes. If set to 0, a default value of 512 KB is used.
Note: In the case where CA ITCM is integrated with CA Common Services (CCS), this parameter is overridden by the corresponding parameter specified in the WorldView component of CCS.
Limits: 0–2147483647
Default: 0
Specifies a delay interval between DTS parcel sends. A throttle value of 20 represents a one-second delay interval between parcel sends.
Limits: 0–100
Default: 0
Specifies the external filter.
Default: sd_dtaflt
Specifies the timeout interval in minutes for DTS filter task 0.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 1.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 2.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 3.
Default: 1440
Specifies the timeout interval in minutes for DTS filter task 4.
Default: 1440
Specifies the timeout interval in minutes for DTS filter task 5.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 6.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 7.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 8.
Default: 10
Specifies the timeout interval in minutes for DTS filter task 9.
Default: 10
Specifies the object description.
Default: SD_DTPUSH
Identify built-in DTS parcel filters. The filters, if specified, are applied in the order they are specified, starting with Parcel filter 0, and applied on the receiving end in reverse order.
The syntax for each parcel filter is:
@<separator character> DTS read parcel filter name [parameter ....] <separator character> DTS write parcel filter name [parameter ... ]
Note: The <separator character> should be chosen carefully; it needs to be distinctive from any other character appearing in the DTS read parcel filter name or its parameters. A space or blank should not be used for this character.
Default: empty
Example:
@? AES256_ENCRYPT ? AES256_DECRYPT
Specifies the API server timeout interval in milliseconds.
Default: 300000 (300 seconds)
Specifies the server connection timeout interval in milliseconds.
Specifies the logon password for the server.
Default: empty
Specifies the networking protocol for the server.
Default: TCP
Specifies the server TOS protocol parameters. When the DTSFT program defines a transfer to DTS, it normally sets up the transfer using the default transfer properties determined by DTS. However, if you specify different values for the following parameters, DTSFT will use these values to override the default values for the associated transfer properties.
Default: IPORT=<8198> RPORT=<ANY>
Specifies the ID of the server user.
Default: empty
Specifies that the retry time interval for the DTS session be overridden. When the DTSFT program defines a transfer to DTS, it normally sets up the transfer using the default transfer properties determined by DTS. However, a value specified here will override the default values for the associated transfer properties.
Default: -1
Specifies that the retry time limit for the DTS session be overridden. When the DTSFT program defines a transfer to DTS, it normally sets up the transfer using the default transfer properties determined by DTS. However, a value specified here will override the default values for the associated transfer properties.
Default: -1
Specifies the shutdown poll interval in seconds, controlling how often the DTS handling component checks for a shutdown request.
Default: 1
Specifies whether the progress indicator for transfers is enabled. A non-zero value specifies that progress should be monitored and files containing the value for the %Sent field be generated. If set to zero (0), the progress indicator is disabled.
Default: 0
Specifies the location of the DTS TOS server if it is not located on the local computer.
Default: localhost
Indicates the number of concurrent transfer job deletion threads to be executed by the file transfer plug-in (sdmgr_ft).
Note: There is no advantage in using more than one deletion thread at this time.
Default: 1
Indicates the number of concurrent transfer job creation threads to be executed by the sdmgr_ft plug-in.
Note: There is no advantage in using more than one creation thread at this time.
Default: 1
Indicates the number of concurrent transfer job threads for simple actions to be executed by the sdmgr_ft plug-in
Note: There is no advantage in using more than one simple action thread at this time.
Default: 1
Specifies whether to use encryption for NOS-less software package transfers. You can set the parameter value to Yes or No. Setting the value to Yes enables encryption for NOS-less software package transfers. However, setting the value to No does not use encryption for NOS-less software package transfers.
Note: When encryption is disabled for NOS-less software downloads, software delivery stops handling the security of the software packages and scripts transferred across the network. So, make sure that you use some other means to protect any sensitive information. However, other NOS-less transfers in software delivery initiated through API-server or -calls follow the default configuration (encryption is enabled) of the File Transfer Server plug-in..
Default: Yes
Specifies the bandwidth limitation of each internal NOS-less software package download. If the value is set to Default, internal NOS-less downloads for software packages between a scalability server and an agent follow the default throttling value of the File Transfer Server plug-in. If a value other than Default is used, internal NOS-less downloads for software packages override the default throttling value and use the configured value. Valid values are Default, Unlimited, 4 Mb, 2 Mb, 1 Mb, 512 Kb, 256 Kb, 128 Kb, 64 Kb, and 32 Kb.
Default: Default
Specifies the cleanup interval in hours, controlling how often the DTS handling component processes the recovery journals to discard obsolete entries.
Default: 24
Specifies that sdmgr_ft journal entries older than the number of days indicated here be discarded. A value of 0 means never discard.
Limits: >=0
Default: 0
Indicates the maximum size in MB of the sdmgr_ft recovery journal at which point new entries will be logged to a new journal.
Default: 10
Defines the command with its parameters for providing a receive filter. Use %s for the file to be filtered and %d for the resulting file.
Default: empty
Defines the command with its parameters for providing a send filter. Use %s for the file to be filtered and %d for the resulting file.
Default: empty
Indicates whether virus scan is enabled. Valid values are True (enabled) and False (disabled).
Default: True
Specifies the timeout interval in seconds for a virus scan.
Default: 600
