Messenger Policy Group
The Messenger policy group contains the following policy for controlling how CAF uses session messaging. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
If set to True, the underlying CAM protocol integrates with the WorldView component of CCS.
Default: False
