Error settings Policy Group
The Error settings policy group contains the following policies for error-related information when the Software Management Installer runs. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the highest possible error entry number, for example, 10. If the maximum value is exceeded, the number is reset to 0.
Default: <locally managed>
