Previous Topic: Software Management Policy GroupNext Topic: Disk space requirements Policy Group
Directories Policy Group (Software Management)
The Directories policy group contains the following policies for the names of important Software Management Installer directories. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Default SxpWinComFilesDir
Specifies the internal SxpWinComFilesDir parameter. This parameter is set to the specified value only if no other entry exists in the registry.
Default: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\CommonFilesDir, <locally managed>
Default SxpWinProgDir
Specifies the internal SxpWinProgDir parameter. This parameter is set to the specified value only if no other entry exists in the registry.
Default: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir, <locally managed>
Script directory
Specifies the script directory. Scripts not distributed with the associated program can be placed in this directory.
Default: empty, <locally managed>
