Default Policy Group
The Default policy group lets you set the following default policies for CA Service Desk Manager integration. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: Available categories and options may vary depending on the products and components installed.
Indicates whether CA Service Desk Manager integration is enabled.
Note: If you change this policy setting to True, you must restart the DSM Explorer GUI to complete the integration process.
Default: False
Defines a reserved field in the MDB for querying all tickets being created by a specified asset or software distribution.
Note: Instead of the default, you may want to reserve one of the string# fields that CA Service Desk Manager provides for user-specific purposes.
Default: summary
Specifies the logon password for CA Service Desk Manager Web Services.
Default: <encrypted>
Specifies the name of the policy to log into if the Type of logon to Service Desk policy is set to notmanaged. If left empty, the default Service Desk policy is used.
Note: A PKCS#12 certificate includes a policy description that will always override this value.
Default: MANAGED_ASSET_EVENTS
Defines the user account for the logon to CA Service Desk Manager Web Services.
Default: System_MA_User
Specifies the URL to CA Service Desk Manager Web Services. Replace myhost with the appropriate server address for your installation. Note that port 8080 is the default port.
Default: http://myhost:8080/axis/services/USD_R11_WebService
Indicates whether networking and CPU throttling are enabled.
Default: False
Specifies the timeout interval for calls to CA Service Desk Manager Web Services. Valid values are as follows:
Default: 120
Example: A value of 200 means a call will time out after 200 seconds, but a value of -200 means it will time out after 200 milliseconds.
Indicates how logon to CA Service Desk Manager Web Services is controlled. Valid values are as follows:
Managed by PKCS#12 certificate.
Managed by user account and password.
Default: managed
