Macro Policy Group
The Macro policy group contains the following policies for customizing the three classes of expansion macros. If the expansion macros are empty, then the default macro is enforced by the agent. The default macro is dependent upon the locale where the agent has been installed; so, for example, if the German version of the agent has been installed, then the default macro will be in German.
You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog. As with all policies, the values set here override the default values used by the agent, regardless of locale.
Define the standard month/day/year formats, which may vary according to operating system and locale differences. Accessed by the ${DateFormatn} or ${DFn} macro.
Default: empty
Defines the first day of the week using the complete (long day) name in the local language. For example, on English systems Sunday is the first day of the week, but in other locales the first day of the week may be Monday. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the second day of the week using the complete name in the local language. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the third day of the week using the complete name in the local language. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the fourth day of the week using the complete name in the local language. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the fifth day of the week using the complete name in the local language. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the sixth day of the week using the complete name in the local language. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the last day of the week using the complete name in the local language. Used by the ${DateDayLong} and ${DDL} macros.
Default: empty
Defines the first month of the calendar year using the complete (long month) name in the local language. For example, on English systems January is the first day of the Gregorian calendar year. Other locales may use different types of calendars, for example, a Chinese, Hebrew, Hindu, or Islamic calendar. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the second month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the third month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the fourth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the fifth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the sixth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the seventh month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the eighth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the ninth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the tenth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the eleventh month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the twelfth month of the calendar year using the complete name in the local language. Used by the ${DateMonthLong} and ${DML} macros.
Default: empty
Defines the first day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the second day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the third day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the fourth day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the fifth day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the sixth day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the last day of the week using the abbreviated day name in the local language. Used by the ${DateDayShort} and ${DDS} macros.
Default: empty
Defines the first month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the second month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the third month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the fourth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the fifth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the sixth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the seventh month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the eighth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the ninth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the tenth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the eleventh month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Defines the twelfth month of the calendar year using the abbreviated month name in the local language. Used by the ${DateMonthShort} and ${DMS} macros.
Default: empty
Define the standard hour/minute/second formats, which may vary according to operating system and locale differences. Accessed by the ${TimeFormatn} or ${TFn} macro.
Default: empty
Indicate user-defined expansion macros. Accessed by the ${UserDefinedn} or ${UDn} macro.
Default: empty
