Scheduler Policy Group
The Scheduler policy group lets you view or edit the existing policy properties for the Common Application Framework (CAF) scheduler. It also contains folders for scheduled jobs that CAF will run at the times specified. Each scheduled job has the same properties but different values.
The Scheduler policy group contains the following policies:
Indicates whether the CAF scheduler is enabled. If True, jobs will run if they are individually enabled (see each job folder). If False, no jobs will run.
Default: True
The Scheduler policy group also contains the following job folders:
Note: Available categories and options may vary depending on the products and components installed.
