Software Delivery › Tasks › Create Software Policy › Create Software Policy Wizard: Final Step
- Confirm your selection and specify a name for the software policy.
- If applicable, select the "Seal and activate Software Policy" option (at the domain level) or the "Seal and distribute Software Policy" option (at the enterprise level).
- If the "Do not link this Software Policy to a Target Group" option has been selected in the previous step, this option will not be available (grayed out) on domains. On the enterprise it will still be usable to allow the distribution of unlinked policies from the enterprise.
- Select the "Open the advanced software policy settings dialog when the Finish button is pressed" option when appropriate. Then the "New Software Policy" dialog will open.
More information:
Distributed Software Policy Properties
Software Policy Properties: Automation Tab
Software Policy Properties: Software Policy
Software Policy Properties: Evaluation
