With this dialog you provide the evaluation method for the software policy.
If you select scheduled evaluation, you can set, and change, the Activation time, Evaluation period and CCS calendar.
The evaluation schedule enables automatic evaluation of the query and/or the policy for the current computer group. The evaluation of the group is performed in the background on the manager.
Specifies when the next evaluation will take place.
See job options.
The minimum period, in hours, that must elapse between two successive evaluations.
The CCS calendar controls the times when scheduled evaluation is allowed. When the calendar is off, no evaluation will take place.
The calendar you select controls the times when scheduled evaluation is allowed. If the calendar is off, no evaluation will take place. If no calendar entry is set, evaluation is done according to the Update periodically setting.
Ad-hoc target evaluation is triggered when agents contact the manager to report inventory.
Evaluation of the reporting targets is performed as a background task.
If you mark the check box "Enable ad-hoc target evaluation for the group", you have to select one of the two alternative ways of ad-hoc target evaluation:
