The Stage Software Package wizard will guide you when you stage software packages on domains and on scalability servers attached to the enterprise.
The result is a software distribution which can be used to track the progress of the distribution to the domains.
The wizard has the following steps:
If you check the box "Open the advanced job settings dialog when the Finish button is pressed", you will be taken to the Setup Jobs dialog window.
