Previous Topic: Create Software Staging Distribution JobNext Topic: Stage Software Package Wizard
Modify Software Policy
Follow these steps to modify a Software based Policy:
1. Right click on the Software Policy and select Unseal to Disable/Edit.
2. Expand the Software Policy and click on the Jobs node.
3. Right click on a job and select Delete to remove a job from the Software Policy.
4. To add a new job, expand the Software Package Library node and select one or more Software Packages.
5. Drag and drop the Software Packages onto the Software Policy Jobs node.
6. Finally, re-seal the Software Policy by selecting Seal to Activate from the popup menu.
Note: On the CA ITCM Enterprise the modified Software Policy must be re-distributed to the Domains: Create a new Distribution Container and then drag and drop the policy on it. Finally, drag and drop the Distribution Container on the Domains.
