A Container contains orders that are executed at the domains.
Select one of the following actions:
Software to register
Software to deregister
Software to purge and mark as archived
Software to restore purged
Added procedures to register
Added procedures to deregister
Software policy to register
Software policy to deregister
By clicking the Set as default button, you save the settings in the Registry of the computer you are currently using.
If there are more people connecting to the same manager, each using Set as Default, each user will have the own settings saved, in a personal user registry.
The default settings only work for the job specific options. The procedure specific options use the default value from the procedure options.
Deletes the item
Opens the Permissions window displaying the object permissions.
Opens the Distribution Properties window
Note: Software package and Software Policy registration orders are added by dropping these items on the container. Software job orders are added by dropping Software directly on the Computer and User Groups.
