The fetched items folder displays the items that have been fetched from the associated area. Apart from the fetched item name column, there are three more columns in the right pane:
Name of the fetched item
If one was entered when the fetch item order was created
Date and time when the fetched item was received
No, if no copy has been made of the fetched item, Yes, if the context menu command Make a Copy has been used to make a copy, in a selected directory, of the fetched files.
