Previous Topic: VolumeNext Topic: Volume File
Volume Directory
A directory in a software package volume.
When you right-click a directory, you can select one of the following actions:
Paste
Paste folders or files into the directory
Scan Viruses
Perform a virus scan for the item.
The action itself is carried out not by CA ITCM, but by the virus checking program configured.
It may be the case that the virus scanner is using another name of the software (based on its UUID) than CA ITCM.
Note: This feature is available when a CA virus scanner is installed. Otherwise it is grayed out in the dialog.
Delete
Delete the directory.
Tip: You can drag and drop directories and files from the Windows Explorer and add them to the volume. You can also use the clipboard.
